Hello, I bought the DIY Pro Kit as my first electronics project. I assembled it and got it running with this github repo GitHub - ajfriesen/ESPHome-AirGradient: ESPHome config for AirGradient Air Quality Sensor for home assistant integration (I had to install the PR to get the temp/humidity working). It is using the defaults for air-gradient-pro-diy.yaml.
Upon monitoring the results I get 0s for Concentrations. I’ve had it running for several hours a couple of different times. The logs are also filled with the info below every second. I don’t see any log for sensor output on PM.
| Name | State |
| AirGradient Pro Particulate Matter <1.0µm Concentration | 0 µg/m³ |
| AirGradient Pro Particulate Matter <10.0µm Concentration | 0 µg/m³ |
| AirGradient Pro Particulate Matter <2.5µm Concentration | 0 µg/m³ |
| AirGradient Pro Particulate Matter >0.3µm Count | 168 /dL |
| AirGradient Pro Particulate Matter >0.5µm Count | 46 /dL |
| AirGradient Pro Particulate Matter >1.0µm Count | 4 /dL |
| AirGradient Pro Particulate Matter >2.5µm Count | 0 /dL |
| AirGradient Pro Relative Humidity | 28.37 % |
| AirGradient Pro SenseAir CO2 Value | 1171 ppm |
| AirGradient Pro Temperature | 24.97 °C |
| Flash Mode (Safe Mode) | OFF |
| NOx Index | 1 |
| Uptime Sensor | 783 s |
| VOC Index | 99 |
| WiFi Signal Sensor | -65 dBm |
12:26:35 [W] [component:214] Component sgp4x.sensor took a long time for an operation (0.06 s).
12:26:35 [W] [component:215] Components should block for at most 20-30ms.
12:26:35 [W] [component:214] Component ssd1306_base took a long time for an operation (0.32 s).
12:26:36 [W] [component:214] Component sgp4x.sensor took a long time for an operation (0.06 s).
