I added a outside sensor to my dashboard. The pm2.5 readings on the map show 22 when i look at the sensor data values are never below 30. Sensors in my neighbourhood are also showing values 22. How does this work? Why the difference between the map and my sensor? Thank you.
edit 1: it looks like it has something to do with RAW data at this time RAW PM2.5 = 32, ‘normal’ PM2.5 - 17,67. inst that strange?
edit 2: today the map shows the same value as the sensor, i cannot explain why, is it because my sensor is only there since a few days?
