It’s hard to tell from the DIY assembly description which wires to use on the PM2.5 sensor. Can someone confirm:
With the flat side of the white connector facing down,
- The very top wire (black) is Vcc
- The next (red) wire is Gnd
- A black wire is skipped (cut off)
- Then the next (red) wire is Rx
- The final used (black) wire is Tx.
In summary: Use 2 wires, skip 1, use 2, skip 3.
