I’ve received a DIY PRO kit, and am attempting to compile the DIY_PRO_WITH_SGP40.ino sketch for it. I chose this sketch because my kit has an SGP41 sensor.
I’ve installed the required libraries:
WifiManagerby tzapu v2.0.11-beta -
U8g2by oliver v2.32.15 -
DFRobot_SGP40by DFRobot v1.0.3 -
AirGradient Air Quality Sensorby AirGradient v2.4.3 (also tried 2.4.1 & 2.4.2)
Compilation fails with:
/Users/roens/Documents/Arduino/libraries/AirGradient_Air_Quality_Sensor/AirGradient.cpp: In member function 'TMP_RH AirGradient::returnError(TMP_RH_ErrorCode)':
/Users/roens/Documents/Arduino/libraries/AirGradient_Air_Quality_Sensor/AirGradient.cpp:684:14: warning: converting to non-pointer type 'float' from NULL [-Wconversion-null]
684 | result.t = NULL;
/Users/roens/Documents/Arduino/libraries/AirGradient_Air_Quality_Sensor/AirGradient.cpp:685:15: warning: converting to non-pointer type 'int' from NULL [-Wconversion-null]
685 | result.rh = NULL;
/Users/roens/Documents/Arduino/libraries/U8g2/src/clib/mui_u8g2 2.c: In function 'mui_u8g2_u8_bar_mse_msg_handler':
/Users/roens/Documents/Arduino/libraries/U8g2/src/clib/mui_u8g2 2.c:962:24: error: 'MUI_MMS_NO_WRAP' undeclared (first use in this function); did you mean 'MUI_MMS_2X_BAR'?
962 | if ( flags & MUI_MMS_NO_WRAP )
| MUI_MMS_2X_BAR
/Users/roens/Documents/Arduino/libraries/U8g2/src/clib/mui_u8g2 2.c:962:24: note: each undeclared identifier is reported only once for each function it appears in
/Users/roens/Documents/Arduino/libraries/U8g2/src/clib/mui_u8g2 2.c: In function 'mui_u8g2_u8_bar_mud_msg_handler':
/Users/roens/Documents/Arduino/libraries/U8g2/src/clib/mui_u8g2 2.c:1026:24: error: 'MUI_MMS_NO_WRAP' undeclared (first use in this function); did you mean 'MUI_MMS_2X_BAR'?
1026 | if ( flags & MUI_MMS_NO_WRAP )
| MUI_MMS_2X_BAR
exit status 1
I’m using a MacBook Pro M2, with the Arduino IDE for macOS M1/M2.
