Compatible TVOC/NOx sensor for DIY Basic Kit
Hi!
Is the SGP41 TVOC Module compatible with the DIY Basic Kit?
If not, which TVOC/NOx sensor would be compatible?
Thanks,
Sebastian
The DIY basic kit has only one slot used by the temp/RH sensor that would be compatible. You could theoretically plug in the TVOC module instead but there is no software support in the example code.
