CO2 S8 sensor not found in O-1PST
Hi, I am getting a failure on the detection of the S8 Sensor. I am wondering if someone can help me to troubleshoot.
The full log:
*wm:AutoConnect: SUCCESS
*wm:STA IP Address: 192.168.68.104
Webserver init: airgradient_84fce606f490.local
Post payload: {"wifi":-48,"boot":0}
WiFi connected!
IP address:
192.168.68.104
Get server config: {"country":"MX","pmStandard":"ugm3","co2CalibrationRequested":false,"ledBarTestRequested":false,"ledBarMode":"off","displayMode":"on","placeOpen":true,"abcDays":8,"tvocLearningOffset":12,"noxLearningOffset":12,"temperatureUnit":"c","targetFirmware":"3.1.0","model":"O-1PST"}
Server configuration:
inF: false
inUSAQI: false
useRGBLedBar: 0
Model: O-1PST
MQTT Broker:
S8 calibration period: 8
Guru Meditation Error: Core  0 panic'ed (Load access fault). Exception was unhandled.
Core  0 register dump:
MEPC    : 0x4201cff2  RA      : 0x4201e970  SP      : 0x3fca0f20  GP      : 0x3fc8f800
TP      : 0x3fc71844  T0      : 0x7fffffff  T1      : 0x4038d5b0  T2      : 0xffffffff
S0/FP   : 0x3fc9d0b4  S1      : 0x3fc99420  A0      : 0x00000000  A1      : 0x00000000
A2      : 0x3fcad4dc  A3      : 0x00000001  A4      : 0x3fc9975c  A5      : 0x00000001
A6      : 0x3fe00000  A7      : 0x00000113  S2      : 0x00000001  S3      : 0x00000000
S4      : 0x3fc93000  S5      : 0x3fc99000  S6      : 0x3fc92e6c  S7      : 0x3fc99000
S8      : 0x3c0e2000  S9      : 0x3c0e13f4  S10     : 0x3fc93000  S11     : 0x00000000
T3      : 0x0000005c  T4      : 0x00000000  T5      : 0x00000000  T6      : 0x20746547
MSTATUS : 0x00001881  MTVEC   : 0x40380001  MCAUSE  : 0x00000005  MTVAL   : 0x00000004
MHARTID : 0x00000000
Stack memory:
3fca0f20: 0x3fc92e6c 0x3fc99420 0x3fca0f98 0x00000000 0x00000001 0x3fc99420 0x3fc94000 0x42006a8e
3fca0f40: 0x3c0e7e5c 0x3fcESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x7 (TG0WDT_SYS_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x4203795e
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5810,len:0x438
load:0x403cc710,len:0x918
load:0x403ce710,len:0x25f4
entry 0x403cc710
Serial nr: 84fce606f490
Detect OPEN_AIR
inF: false
inUSAQI: false
useRGBLedBar: 0
Model: O-1PST
MQTT Broker:
S8 calibration period: -1
Firmware Version: 3.0.9
Can not detect S8 on Serial1, try on Serial0
Can not detect S8 run mode 'PPT'
Found PMS 1 on Serial0
PMS2 sensor not found
Firmware Mode: O-1PPT
Connecting to WiFi...
*wm:AutoConnect
*wm:Connecting to SAVED AP: ElInternet
*wm:connectTimeout not set, ESP waitForConnectResult...
Post response failed code: -11
WiFi connected!
IP address:
192.168.68.104
inF: false
inUSAQI: false
useRGBLedBar: 0
Model: O-1PST
MQTT Broker:
Here is a photo of my connections:
Thanks in advance,
Just to add, the connections I got from:
https://www.airgradient.com/documentation/open-air-pst-kit-1-3/
And I also followed this related thread:
Which firmware version are you on?
Any way I can check this directly?
Two facts:
Thanks for answering and any help you can provide!
Please send me your place ID that you can see here: AirGradient
This is what I found in the page that you linked (I am writing this because of the 20 character limit).
Place ID: 5859
I looked at the dashboard but all looks fine. It seems you only get TVOCs sometime. Can you try and use a different power adapter?
If that does not help, please send more photos.
I tried using a different power source, I also tried connecting it to the computer with the cable that came wit hthe pakcage. No luck, also now it seems that I don’t get the data of PM to the dashboard either : /
More photos, let me know if you anyhintg else could be useful:
And the latest logs:
Processing: esp-web-tools-logs.txt…
TVOC index: 89
TVOC raw: 29630
NOx index: 1
NOx raw: 16698
[1] PM1 ug/m3: 22
[1] PM2.5 ug/m3: 33
[1] PM10 ug/m3: 35
[1] PM3.0 Count: 4080
[1] Temperature in C: 25.36
[1] Relative Humidity: 52
TVOC index: 90
TVOC raw: 29623
NOx index: 1
NOx raw: 16692
TVOC index: 90
TVOC raw: 29624
NOx index: 1
NOx raw: 16693
[1] PM1 ug/m3: 22
[1] PM2.5 ug/m3: 32
[1] PM10 ug/m3: 34
[1] PM3.0 Count: 4017
TVOC index: 91
TVOC raw: 29624
NOx index: 1
NOx raw: 16686
TVOC index: 91
TVOC raw: 29621
NOx index: 1
NOx raw: 16679
TVOC index: 92
TVOC raw: 29621
NOx index: 1
NOx raw: 16673
[1] PM1 ug/m3: 22
[1] PM2.5 ug/m3: 32
[1] PM10 ug/m3: 34
TVOC index: 92
TVOC raw: 29621
NOx index: 1
NOx raw: 16673
[1] PM1 ug/m3: 22
[1] PM2.5 ug/m3: 32
[1] PM10 ug/m3: 33
[1] PM3.0 Count: 4038
TVOC index: 92
TVOC raw: 29624
NOx index: 1
NOx raw: 16669
TVOC index: 93
TVOC raw: 29617
NOx index: 1
NOx raw: 16667
TVOC index: 93
TVOC raw: 29638
NOx index: 1
NOx raw: 16656
[1] PM1 ug/m3: 22
[1] PM2.5 ug/m3: 32
[1] PM10 ug/m3: 35
[1] PM3.0 Count: 4050
TVOC index: 94
TVOC raw: 29622
NOx index: 1
NOx raw: 16650
[1] PM1 ug/m3: 21
[1] PM2.5 ug/m3: 30
[1] PM10 ug/m3: 32
[1] PM3.0 Count: 3918
TVOC index: 94
TVOC raw: 29627
NOx index: 1
NOx raw: 16648
TVOC index: 94
TVOC raw: 29624
NOx index: 1
NOx raw: 16627
[1] PM1 ug/m3: 21
[1] PM2.5 ug/m3: 30
[1] PM10 ug/m3: 32
TVOC index: 94
TVOC raw: 29634
NOx index: 1
NOx raw: 16629
TVOC index: 95
TVOC raw: 29631
NOx index: 1
NOx raw: 16625
[1] PM1 ug/m3: 21
[1] PM2.5 ug/m3: 30
[1] PM10 ug/m3: 33
[1] PM3.0 Count: 3867
TVOC index: 95
TVOC raw: 29620
NOx index: 1
NOx raw: 16618
TVOC index: 95
TVOC raw: 29634
NOx index: 1
NOx raw: 16613
[1] PM1 ug/m3: 21
[1] PM2.5 ug/m3: 31
[1] PM10 ug/m3: 33
[1] PM3.0 Count: 3783
TVOC index: 95
TVOC raw: 29628
NOx index: 1
NOx raw: 16605
TVOC index: 95
TVOC raw: 29628
NOx index: 1
NOx raw: 16605
[1] PM1 ug/m3: 21
[1] PM2.5 ug/m3: 32
[1] PM10 ug/m3: 34
[1] PM3.0 Count: 3828
TVOC index: 96
TVOC raw: 29621
NOx index: 1
NOx raw: 16608
TVOC index: 96
TVOC raw: 29619
NOx index: 1
NOx raw: 16601
[1] PM1 ug/m3: 20
[1] PM2.5 ug/m3: 31
[1] PM10 ug/m3: 35
[1] PM3.0 Count: 3897
TVOC index: 96
TVOC raw: 29623
NOx index: 1
NOx raw: 16596
TVOC index: 96
TVOC raw: 29621
NOx index: 1
NOx raw: 16585
[1] PM1 ug/m3: 20
[1] PM2.5 ug/m3: 31
[1] PM10 ug/m3: 35
TVOC index: 97
TVOC raw: 29612
NOx index: 1
NOx raw: 16583
TVOC index: 97
TVOC raw: 29626
NOx index: 1
NOx raw: 16580
Post payload: {"wifi":-44,"channels":{"1":{"pm01":20,"pm02":31,"pm10":35,"pm003_count":3897,"atmp":25.36,"rhum":52}},"tvoc_index":97,"tvoc_raw":29626,"nox_index":1,"nox_raw":16580,"boot":1}
Post response failed code: 400
[1] PM1 ug/m3: 21
[1] PM2.5 ug/m3: 32
[1] PM10 ug/m3: 36
[1] PM3.0 Count: 3891
Can you please send a longer log where we can see the unit starting up?
Detect OPEN_AIR
inF: false
inUSAQI: false
useRGBLedBar: 2
Model: O-1PST
MQTT Broker:
CO2 S8 sensor notFound PMS 1 on Serial0
*wm:AutoConnect
*wm:STA IP Address: 192.168.68.107
Post payload: {"wifi":-43,"boot":0}
WiFi connected!
IP address:
192.168.68.107
Get server config: {"country":"MX","pmStandard":"ugm3","co2CalibrationRequested":false,"ledBarTestRequested":false,"ledBarMode":"co2","displayMode":"on","placeOpen":true,"abcDays":30,"tvocLearningOffset":12,"noxLearningOffset":12,"temperatureUnit":"c","targetFirmware":"3.1.0","ledbarBrightness":100,"displayBrightness":100,"model":"O-1PST"}
inF: false
inUSAQI: false
useRGBLedBar: 2
Model: O-1PST
MQTT Broker:
S8 calibration period: 30
inF: false
inUSAQI: false
useRGBLedBar: 2
Model: O-1PST
MQTT Broker:
CO2 S8 not available, set 'abcDays' ignored
[1] PM1 ug/m3: 27
[1] PM2.5 ug/m3: 39
[1] PM10 ug/m3: 46
[1] PM3.0 Count: 0
[1] Temperature in C: 24.65
[1] Relative Humidity: 53
TVOC index: 0
TVOC raw: 29108
NOx index: 0
NOx raw: 16222
TVOC index: 0
TVOC raw: 29185
NOx index: 0
NOx raw: 16198
[1] PM1 ug/m3: 25
[1] PM2.5 ug/m3: 38
[1] PM10 ug/m3: 44
[1] PM3.0 Count: 5328
[1] Relative Humidity: 54
TVOC index: 0
TVOC raw: 29257
NOx index: 0
NOx raw: 16177
TVOC index: 0
TVOC raw: 29323
NOx index: 0
NOx raw: 16161
[1] PM1 ug/m3: 26
[1] PM2.5 ug/m3: 39
[1] PM10 ug/m3: 46
[1] PM3.0 Count: 5313
[1] Temperature in C: 24.77
TVOC index: 0
TVOC raw: 29376
NOx index: 0
NOx raw: 16151
TVOC index: 0
TVOC raw: 29428
NOx index: 0
NOx raw: 16136
[1] PM1 ug/m3: 26
[1] PM2.5 ug/m3: 39
[1] PM10 ug/m3: 45
[1] PM3.0 Count: 5211
TVOC index: 0
TVOC raw: 29469
NOx index: 0
NOx raw: 16134
TVOC index: 0
TVOC raw: 29512
NOx index: 0
NOx raw: 16126
[1] PM1 ug/m3: 26
[1] PM2.5 ug/m3: 39
[1] PM10 ug/m3: 45
[1] PM3.0 Count: 5238
I think it might be a faulty CO2 module. Please contact our support through the website form to get you a replacement.
I wanted to report that I got my sensor last month (not delay on the company part it is just that I was slow to order it and slow to pick it up). I installed it today and it works perfectly.
Thanks a bunch for solving my problem. I really appreciate how promptly you addressed it.
I had very similar symptoms with my brand-new O-1PST (Kit). At first I thought it was a calibration issue, but then I went into debug mode and saw the same error you reported:
Can not detect S8 run mode ‘PPT’
I started digging deeper and checked the cable and connectors with a short-circuit tester. Finally, I found a missing connection between the UART_TxD pin of the S8 sensor and the socket on the S8 AirGradient breakout board, caused by insufficient soldering on the pin.
I heated up my soldering iron, added some extra solder to the pin, and ended up with a working sensor.
Hi @liszi! Thanks for reporting this!
