CO2 measurement temperature/RH compensation?
Is there some form of temperature/RH compensation regarding the CO2 measurement?
I just deployed an indoor and an outdoor unit today, so I am just getting familiar with the possibilities and trying to come up with meaningful workflows.
This is what I experienced:
0. I have calibrated the indoor units CO2 measurement (left it outside for 20 minutes, clicked on calibrate button, CO2 value went to 400). I brought the device back into the house. Outside: 7 Celsius
  1. Inside, the device immediately started to show 2000ppm CO2 level, and still a low temperature. In 5-10 minutes the shown temperature converged to the actual temperature (21 C), and the shown CO2 went down to around 1150 ppm
  2. I have opened all windows. CO2 very quickly went down to 450ppm. Shown temperature was decreasing much slower. As temperature decreased, CO2 started to increase(!) after some time to approx 500ppm, from there it started to decrease slowly again.
  3. I have closed the windows. Both temperature and CO2 started to increase gradually. It took about 30 minutes for the displayed temperature to the reach the normal internal 21C(I guess as a result of the inertia of both the heating and the sensor), and the CO2 increased in a similar gradient, meaning that CO2 is back to the original 1150 ppm just 30 minutes after thorough ventilation.
So basically it seems like that the CO2 level is the same 30 minutes after ventilation as was before the ventilation.
Based on this experience I have a feeling that CO2 is somehow compensated by the temperature/RH measurement, and the different inertia of the different values/sensors might caused the experienced outcome.
I would like to understand this mechanism to a level which would make me capable to properly schedule the start and end time of the ventilation based on the values shown by the sensor, if that possible, to keep the inhouse CO2 level relatively low with the minimum amount of ventilation.
I’m pretty sure that temp/hum does not factor into the CO2 levels, or at least not as part of the AirGradient code.
When you start ventilating a room, you may change the temp and CO2 concentrations in that room or nearby rooms, but once you close up, any other CO2 built up in other rooms will start to spread and can cause the increase over time, similar to the temperature increasing.
But what happened when I brought the sensor in the heated room from the cold, it started to display 2000ppm, then without ventilation, it went down to 1150ppm?
Seems like the sensor is impacted by changing temperatures/RH somehow.
Thank you for confirming that the Airgradient code doesn’t change/compensate the displayed CO2 value based on temperature/RH!
That’s a super interesting observation!
The point you made in Post #3 about the CO2 spiking to 2000ppm when you bring the sensor in from the cold, and then slowly settling down, is spot on. Even though the AirGradient code might not be adding compensation, the NDIR sensor itself (like the SenseAir S8 or similar) has internal temperature compensation.
When the sensor experiences a sudden temperature shock, it takes a bit of time for its internal components to thermally stabilize, which causes those temporary, way-off readings. It’s the sensor reacting to the rapid change before its internal compensation can catch up.
