Cannot connect to device via local network
Trying to follow Local Server Documentation
I’ve got the indoor monitor connected to my LAN and sending data over to the AirGradient dashboard, but when I try to connect to the device locally (in order to ping the API endpoint to store data in prometheus), I can’t get any connection to the device.
I’m operating on 10.25.x.x rather than 192.168.x.x - could this cause an issue? I can see the device on my router (with IP 10.25.0.187) but as other posters have mentioned, I should use a static IP for prometheus rather than mDNS.
Any pointers here to be able to connect to the local device would be much appreciated.
➜  ~ ping 10.25.0.187
PING 10.25.0.187 (10.25.0.187) 56(84) bytes of data.
From 10.25.0.9 icmp_seq=1 Destination Host Unreachable
From 10.25.0.9 icmp_seq=2 Destination Host Unreachable
From 10.25.0.9 icmp_seq=3 Destination Host Unreachable
^C
--- 10.25.0.187 ping statistics ---
4 packets transmitted, 0 received, +3 errors, 100% packet loss, time 3077ms
for reference, other devices respond (e.g. NAS server), so I’m wondering if i’m missing a port number, but then if a ping doesn’t work then it’s like the device isn’t responding on that IP address.
➜  ~ nmap 10.25.0.187
Starting Nmap 7.80 ( https://nmap.org ) at 2024-05-04 10:42 WEST
Note: Host seems down. If it is really up, but blocking our ping probes, try -Pn
Nmap done: 1 IP address (0 hosts up) scanned in 3.05 seconds
this indicates the device is not responding on that IP at all - could this be an issue with the device?
Which firmware are you on?
This is what’s reported via the AirGradient dashboard
Monitor Maker: AirGradient
Linked Location: Indoor
Firmware Version: 1.1.2
Model: I-9PSL-DE
Monitor Commissioning Date: May 3, 2024
fixed - after upgrading the firmware to 3.0.10-beta2 everything is working and i’ve now got this hooked up to prometheus/grafana!
