Can I mount my outdoor sensor on a roof mast?
Hello! I just received my AirGradient Open Air outdoor AQM. I know the mounting instructions indicate a specific height above the ground: " Height: Please do not place the sensor below 100cm or above 300cm on the wall. Ideally it should be placed between 150-250cm." However, I’d like to mount it on an existing mast on the roof of my home to get the sensor out of the close trees that surround my home. I just kind of assume the trees would interfere. This would be some 30’ above ground (average, my home is on a hill) and then I could get the 150-240cm above the roof itself on the mast. This is in Minnesota, so I’m watching wildfire pollutants specifically.
Does this strategy still produce valid data?
Lion
Yes, in that case it is no problem. The maximum height is actually not that important and I will remove it from the instructions.
