Barometric sensor, which ones are supported?
I am looking at ordering a pro kit but I can’t find information on which barometric sensors are compatible. Any advice?
Thank you,
PB
2 more questions after quick googling …
Is there place to add 2 sensors in there for TVOC and a barometric ? If not, is the BME688 supported (tvoc, gas pressure, temperature, etc) or something similar?
We would not recommend adding too many i2c sensors on the bus and you might need to remove the pull up resistors.
If you like to use a TVOC sensor then order the one from our shop as this one does not have pull ups and will work stable.
