Hello there,
I just purchased an AirGradient pre-soldered version and had it lying around for a week to hopeful get more stable values.
In the first week, I had the stock version running, and it’s been showing:
CO2 ppm - averaging 1.5-2k in the day, and 4000+ overnight, rarely dips below 1k when venting the room.
Temperature - 2c on average above a wall-mounted regulator for my floor heating
humidity - 3-6% below a humidifier that’s sitting around and used for reading values.
I just updated it to v3.0.6 2MAR24 and left it lying around for a couple of minutes, it fixed the humidity readings but the temperature readings stay the same.
I’m concerned with CO2 ppm levels, since it’s been very difficult to get them below 1000 ppm.
Would there be other alternatives to verify which readings are accurate other than finding more devices to see which values agree with each other?
Note:
- I live in Austria.
- I found a physical thermometer and it’s temperature seems to agree with the Airgradient monitor which may indicate that the wall-mounted sensor is off. Potentially being cooled down by the wall in winter?
- Added some pictures of the devices I’m using.
