I just received and assembled the pre-soldered kit and have some feedback on the experience. Ultimately I was successful, but the instructions were unnecessarily frustrating. I get this is a DIY type niche product, but if you intend it to be more widely used, these things should really be addressed.
The diagrams don’t show pictures of the actual PCB being assembled, just diagrams. The D1 Mini in particular confused me and I plugged it in reversed. This seemed logical because it had the USB-C port pointing towards the exterior of the device. The diagram was not helpful at all in that.
The device came with two types of screws, and don’t tell you which to use. I tried the longer ones first for the PMS module, which was of course wrong. Not a huge deal but it was unnecessary.
Speaking of screws, I ended up with 4 extra of the stubby ones and 0 of the long ones. Is this intended? Did I mess up? I don’t think I did, but honestly don’t know.
Still on screws! There are zero instructions how to put the case together. It wasn’t immediately visible how to do it. I figured it out, the long screws go into hidden little holes, but instructions were non-existant here.
The delay when the device boots up, where you can hit the button to change OLED naming and orientation, is extremely short. Again I made it work but adding, say, 2 seconds would help a lot there.
Speaking of orientation, the default orientation on the OLED is upside-down. The logo on the case would be upside-down if left alone. Easy enough to reverse it (once you get that ultra-short delay down) but the default should be correct, don’t you think? How many people just left it that way?
While the instructions do talk about flashing, they don’t make it clear that the device won’t work in HomeAssistant without being flashed with ESPhome. So now I need to open it back up and flash it. Normally that wouldn’t be a huge deal but I’m pretty scared of stripping the little plastic threads in the screw holes. Definitely suggest a big bold notification telling people they need to do this-- and it would be very cool if there was some way to do it through your dashboard, too.
