I’m wondering if an ESPHome update has broken the yaml configs for the AirGradient Open Air O-1PST? This is the error I’m getting on my HomeAssistant ESPHome Builder:
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome/airgradient-outdoor-aqm.yaml…
Failed configpackages: [source /config/esphome/airgradient-outdoor-aqm.yaml:43]
board: github://airgradienthq/esphome/packages/airgradient_esp32-c3_board.yamlFailed to load packages. packages/sensor_pms5003t.yaml is not a valid YAML file. Please check the file contents.
while parsing a block mapping
in “/data/packages/4781b3f7/packages/sensor_pms5003t.yaml”, line 52, column 7
expected , but found ‘’
in “/data/packages/4781b3f7/packages/sensor_pms5003t.yaml”, line 53, column 9.
pm_2.5: github://airgradienthq/esphome/packages/sensor_pms5003t.yaml
co2: github://airgradienthq/esphome/packages/sensor_s8.yaml
tvoc: github://airgradienthq/esphome/packages/sensor_sgp41.yaml
airgradient_api: github://airgradienthq/esphome/packages/airgradient_api_esp32-c3.yaml
hardware_watchdog: github://airgradienthq/esphome/packages/watchdog.yaml
wifi: github://airgradienthq/esphome/packages/sensor_wifi.yaml
mac_address: github://airgradienthq/esphome/packages/sensor_mac_address.yaml
I checked the packages/sensor_pms5003t.yaml file and I don’t see any obvious formatting issues on lines 52 or 53…
My yaml config is:
AirGradient Open Air Outdoor Monitor with CO2 and TVOC
Model: O-1PST
The AirGradient Builds Overview
substitutions:
friendly_name: “AirGradient Open Air”
config_version: 2.0.0
name_add_mac_suffix: “true” # Must have quotes around valueEnable Home Assistant API
api:
encryption:
key: “(redacted)”ota:
- platform: esphome
password: (redacted)wifi:
networks:
- ssid: !secret wifi_ssid
reboot_timeout: 15minEnable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “${upper_devicename} Hotspot”esp32_improv: # Uses around 30% of available flash space due to loading BLE stack
authorizer: noneThe captive portal is a fallback mechanism for when connecting to the configured WiFi fails.
Captive Portal — ESPHome
captive_portal:
dashboard_import:
package_import_url: github://airgradienthq/esphome/airgradient-open-air-o-1pst.yaml
import_full_config: falsepackages:
uptime: github://airgradienthq/esphome/packages/sensor_uptime.yaml
safe_mode: github://airgradienthq/esphome/packages/switch_safe_mode.yaml
My HA version info:
- Core2025.1.4
 - Supervisor2024.12.3
 - Operating System14.2
 - Frontend20250109.2
