I asked via the contact form on the website, but hadn’t heard back and I noticed folks here building the Pro, optionally with a VOC sensor, so thought I might ask here. Is the ONE basically a PRO that’s been prebuilt and includes the VOC sensor?
I’m loving my BASIC kit. I modified it to use an XBee 900MHz as it is in a location where I don’t get Wifi (namely my analog photography darkroom) and also use MQTT into InfluxDB/Grafana on the other end to pull the stats. Works like a champ! And indeed it’s helped me change behaviors in my darkroom.
I also do a lot of 3D printing and recently started doing ABS. ABS is known for vomiting VOCs into the air and when I saw Airgradient has an option to track VOCs, this seemed like a really good idea! So I was thinking about getting the ONE since it already has VOCs, but would like still to be able to mess around with the firmware so I can tailor it to my own needs. I won’t need to use an Xbee for this application but will still want to setup MQTT in a specific way.
Thoughts?
