AirGradient ONE (I-9PSL) cycles connect/disconnect from wifi
Firmware: 3.1.13
Using this with Home Assistant AirGradient Integration.
It keeps disconnecting from Home Assistant and then later reconnecting.
Wifi Signal strength is -35db (right next to the wifi router)
I tried flashing to the latest firmware (3.1.13) with a total wipe of the old firmware, following the instructions here: AirGradient ONE (I-9PSL) and Open Air (O-1PST) Firmware Versions
The leftmost LED turns Purple occasionally, as well as Orange.
And in the AirGradient Home Assistant Integration it say a Firmware Update is available to 3.1.21, but the above firmware page states 3.1.13 is the latest for this model. And when this unit boots, it states “Firmware update fail, will try again”
When I first installed this unit, I set it to Off Line mode as I did not have a network set up to connect it to. But I did a factory reset and then connected it to my wifi network.
Any ideas?
Ok. I rembooted EVERYTHING (modem, router, airgradient, home assistant) and it’s be up and stable for 2 hours now. Soooo, not sure what was causing the issue, but it’s working now.
When in doubt, boot it all!
