I recently set up a new AirGradient One, powered from a battery pack with solar panel feeding it. I am using Home Assistant to access the various sensor outputs. The WiFi signal strength is pretty good and apparently stable. The battery appears to be fine. But, all of the sensor outputs (accessed as Home Assistant entities) become unavailable after multiple hours. They do not recover on their own. So far, I have been disconnecting and reconnecting the power supply, which then results in everything becoming available again. Even prior to connecting the solar panel, the same thing happened, so it’s not a case of the battery going flat and then re-charging later on. Can anybody advise how to investigate the cause please? And why the AirGradient One doesn’t recover automatically? If it’s a WiFi or battery problem, then either should presumably be capable of auto-recovery when signal/battery are at suitable levels.
