It does work fine for a while
but after few mn, it is no longer reacheable in Home assistant or on its IP address.
When I go on the SEP Home and check for the logs, this is what I get
Any clue what’s going on?
INFO ESPHome 2024.4.2
INFO Reading configuration /config/esphome/esphome-web-[redacted].yaml...
INFO Starting log output from [redacted] using esphome API
WARNING Can't connect to ESPHome API for esphome-web-[redacted] @ [redacted]: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='[redacted]', port=6053))]: [Errno 111] Connect call failed ('[redacted]', 6053) (SocketAPIError)
INFO Trying to connect to esphome-web-[redacted] @ [redacted] in the background
INFO Successfully connected to esphome-web-[redacted] @ [redacted] in 1.106s
INFO Successful handshake with esphome-web-[redacted] @ [redacted] in 0.111s
[16:12:46][I][app:100]: ESPHome version 2024.4.2 compiled on May 1 2024, 15:09:50
[16:12:46][I][app:102]: Project esphome.web version 1.0
[16:12:46][C][wifi:580]: WiFi:
[16:12:46][C][wifi:408]: Local MAC: [redacted]
[16:12:46][C][wifi:413]: SSID: 'WiFi'[redacted]
[16:12:46][C][wifi:416]: IP Address: [redacted]
[16:12:46][C][wifi:420]: BSSID: [redacted]
[16:12:46][C][wifi:421]: Hostname: 'esphome-web-[redacted]'
[16:12:46][C][wifi:423]: Signal strength: -22 dB ▂▄▆█
[16:12:46][C][wifi:427]: Channel: 1
[16:12:46][C][wifi:428]: Subnet: 255.255.255.0
[16:12:46][C][wifi:429]: Gateway: [redacted]
[16:12:46][C][wifi:430]: DNS1: [redacted]
[16:12:46][C][wifi:431]: DNS2: 0.0.0.0
[16:12:46][C][logger:166]: Logger:
[16:12:46][C][logger:167]: Level: DEBUG
[16:12:46][C][template.sensor:022]: Icon: 'mdi:air-filter'
[16:12:46][C][template.sensor:023]: Update Interval: 300.0s
[16:12:46][C][uptime.sensor:031]: Uptime Sensor 'Uptime'
[16:12:46][C][uptime.sensor:031]: Device Class: 'duration'
[16:12:46][C][uptime.sensor:031]: State Class: 'total_increasing'
[16:12:46][C][uptime.sensor:031]: Unit of Measurement: 's'
[16:12:46][C][uptime.sensor:031]: Accuracy Decimals: 0
[16:12:46][C][uptime.sensor:031]: Icon: 'mdi:timer-outline'
[16:12:46][C][template.number:050]: Template Number 'Display Contrast %'
[16:12:46][C][template.number:050]: Icon: 'mdi:lightbulb'
[16:12:46][C][template.number:051]: Optimistic: YES
[16:12:46][C][template.number:052]: Update Interval: 60.0s
[16:12:46][C][template.number:050]: Template Number 'LED Brightness %'
[16:12:47][C][template.number:051]: Optimistic: YES
[16:12:47][C][template.switch:068]: Template Switch 'Display Air Quality Page'
[16:12:47][C][template.switch:070]: Icon: 'mdi:monitor'
[16:12:47][C][template.switch:091]: Restore Mode: restore defaults to OFF
[16:12:47][C][template.switch:057]: Optimistic: YES
[16:12:47][C][template.switch:068]: Template Switch 'Display Temp/Hum Page'
[16:12:47][C][template.switch:068]: Template Switch 'Display VOC Page'
[16:12:47][C][template.switch:068]: Template Switch 'Display Combo Page'
[16:12:47][C][template.switch:068]: Template Switch 'Display Boot Page'
[16:12:47][C][sht4x:050]: Address: 0x44
[16:12:47][C][sgp4x:305]: SGP4x:
[16:12:47][C][sgp4x:306]: Address: 0x59
[16:12:47][C][sgp4x:307]: store_baseline: 1
[16:12:47][C][sgp4x:326]: Type: SGP41
[16:12:47][C][sgp4x:327]: Serial number: 94422961
[16:12:47][C][sgp4x:328]: Minimum Samples: 45.000000
[16:12:47][C][sgp4x:330]: Update Interval: 60.0s
[16:12:47][C][ssd1306_i2c:023]: I2C SSD1306
[16:12:47][C][ssd1306_i2c:023]: Rotations: 0 °
[16:12:47][C][ssd1306_i2c:023]: Dimensions: 128px x 64px
[16:12:47][C][ssd1306_i2c:024]: Address: 0x3C
[16:12:47][C][ssd1306_i2c:025]: Model: SH1106 128x64
[16:12:47][C][ssd1306_i2c:027]: External VCC: NO
[16:12:47][C][ssd1306_i2c:028]: Flip X: YES
[16:12:47][D][api:102]: Accepted [redacted]42
[16:12:47][D][api.connection:1210]: Home Assistant 2023.10.3 ([redacted]42): Connected successfully
[16:12:47][D][sgp4x:277]: Sensor has not collected enough samples yet. (6/90) VOC index is: 0
[16:12:48][W][font:112]: Encountered character without representation in font: '$'
[16:12:48][D][pmsx003:236]: Got PM1.0 Concentration: 6 µg/m^3, PM2.5 Concentration 10 µg/m^3, PM10.0 Concentration: 12 µg/m^3
[16:12:48][D][sgp4x:277]: Sensor has not collected enough samples yet. (7/90) VOC index is: 0
[16:12:49][W][font:112]: Encountered character without representation in font: '$'
[16:12:49][D][pmsx003:236]: Got PM1.0 Concentration: 6 µg/m^3, PM2.5 Concentration 10 µg/m^3, PM10.0 Concentration: 12 µg/m^3
[16:12:49][D][sgp4x:277]: Sensor has not collected enough samples yet. (8/90) VOC index is: 0
[16:12:50][W][font:112]: Encountered character without representation in font: '$'
[16:12:50][D][pmsx003:236]: Got PM1.0 Concentration: 5 µg/m^3, PM2.5 Concentration 9 µg/m^3, PM10.0 Concentration: 11 µg/m^3
