I’ve been having some WiFi reception issues for some of my devices, notably my Solar power monitoring solution (A Pi running haproxy connected to the service port of my solar monitor so I can pull stats and push them into Clickhouse and visualize in Grafana). For that solution I was looking at XBee 900 as I’ve used that before (including with AirGradient) but realized LoRA might be a way better option.
Which got me wondering if anyone has extended any of the AirGradients with LoRA capability? I see there’s an ESP32 LoRA module available but it’s not pin compatible with the Wemos D1 (or at least it has a lot more pins and won’t fit in the same footprint).
LoRA might be a good option for the outdoor sensor solution (in fact my own DIY weather station uses XBee 900). At least at my house, the radiant barriers plus the number of Wifi networks around here just crush any Wifi signal outside my house.
Anyways before I went down this path I thought I’d check to see if anyone has done this already and had some thoughts.
