Is there a way to access the Airgradient One data through its USB-C interface? some sort of USB networking, or serial link or something?
For those who dislike wifi
and/or who prefer such type of setup?
Hi @gabu, it is currently possible to access AirGradient ONE and Open Airâs readings via USB log. The data is human-readable. Youâll see the monitor update its raw readings every 6 seconds approximately. Like what is shown below. However, this way (USB log) is primarily intended to be used as a diagnostic tool, so I am not sure about the practical feasibility in your specific use case. We still need Wi-Fi to access the monitorâs local API.
[13:44:22]WiFi RSSI -36
[13:44:22]
[13:44:22]CO2 = 531.33 ppm
[13:44:22]Temperature = 27.97 C
[13:44:22]Relative Humidity = 52.75
[13:44:22]TVOC Index = 106.0
[13:44:22]TVOC Raw = 32311.8
[13:44:22]NOx Index = 1.0
[13:44:22]NOx Raw = 16281.6
[13:44:22][1] Atmospheric PM 1.0 = 2.33 ug/m3
[13:44:22][1] Atmospheric PM 2.5 = 5.67 ug/m3
[13:44:22][1] Atmospheric PM 10 = 6.50 ug/m3
[13:44:22][1] Standard Particle PM 1.0 = 2.33 ug/m3
[13:44:22][1] Standard Particle PM 2.5 = 5.67 ug/m3
[13:44:22][1] Standard Particle PM 10 = 6.50 ug/m3
[13:44:22][1] Particle Count 0.3 = 476.0
[13:44:22][1] Particle Count 0.5 = 366.3
[13:44:22][1] Particle Count 1.0 = 67.0
[13:44:22][1] Particle Count 2.5 = 3.7
[13:44:22][1] Particle Count 5.0 = 1.7
[13:44:22][1] Particle Count 10 = 0.0
[13:44:22]
[13:44:28]External watchdog feed!
[13:44:28]
[13:44:28]CO2 = 531.67 ppm
[13:44:28]Temperature = 27.97 C
[13:44:28]Relative Humidity = 52.64
[13:44:28]TVOC Index = 106.0
[13:44:28]TVOC Raw = 32336.2
[13:44:28]NOx Index = 1.0
[13:44:28]NOx Raw = 16277.9
[13:44:28][1] Atmospheric PM 1.0 = 2.67 ug/m3
[13:44:28][1] Atmospheric PM 2.5 = 6.17 ug/m3
[13:44:28][1] Atmospheric PM 10 = 7.17 ug/m3
[13:44:28][1] Standard Particle PM 1.0 = 2.67 ug/m3
[13:44:28][1] Standard Particle PM 2.5 = 6.17 ug/m3
[13:44:28][1] Standard Particle PM 10 = 7.17 ug/m3
[13:44:28][1] Particle Count 0.3 = 478.7
[13:44:28][1] Particle Count 0.5 = 398.2
[13:44:28][1] Particle Count 1.0 = 97.2
[13:44:28][1] Particle Count 2.5 = 1.7
[13:44:28][1] Particle Count 5.0 = 1.3
[13:44:28][1] Particle Count 10 = 0.3
Oh excellent! I didnt think of just
cat /dev/ttyACM0!
@gabu, my very pleasure.
Also, please feel free to share your approach (if youâd like) on this USB reading. We are always interested in seeing something new or experimental!
Well my idea was to not use WiFi at all, as it is not an essential part of my personal infrastructure (call me âolâfashionedâ but i like me goodâolâcables! ;)) )âŚ
So it got me thinking: what if (through an option or clever reconfiguration⌠or maybe i could attempt one day to modify the firmware in that direction) the /dev/ttyACM0 could, instead of these debug info, output the exact same data as the prometheus output on /metrics ? or (again through configuration option) any other form of the data as required by such or such integrated software, such as currently accessible through the local webserver?
This would potentially allow for more simpler offline configurations like the one i am aiming at?
(would also allow for relatively simple, autonomous and offline portable solutions based on the One, that could move from place to place without needing to be re-associated with different WiFi networksâŚ)
Wired ethernet connectivity with POE power should be a mandatory feature, with WiFi as an option as well.
Thank you for your suggestions @gabu @tadawson !
Do you think Ethernet with PoE should be in both indoor and outdoor monitors, or which one do you think will gain the benefit of having Ethernet with PoE more?
Outdoor monitor
I would like to see ethernet + POE as an option for the outdoor monitor as this gives more flexibility for positioning the monitor. The monitor will always need a cable for power, but its position is limited by having a mains supply or other nearby for the outdoor PSU.
Ethernet + POE overcomes this as it means that the outdoor monitor can be positioned anywhere (within the constraints of the length of cable that can be used) and still get a perfect wifi connection.
Indoor monitor
Whilst useful to have, Iâm not so bothered about Ethernet + POE for the indoor monitor.
I would still like the monitor to have the wifi interface, and an ethernet only (with or without POE) connection could be useful.
Both. No matter how you use it, you are running a cable. The option to remove the bogosities of WiFi and power the monitor is a big plus in either case, although I do suspect that outdoor would be more likely to use this solution.
maybe POE could have its dedicated thread?
Thanks all for your input!
If you have any ideas to suggest any features, please feel free to create a thread. Iâm looking forward to discussing the interesting ideas you have!
so to summarize and re-formulate my proposal, after a few days of playing with the Airgradient One, and exploring a few ways of using it as a reliable data-source is the following:
=> I think the USB data link should be used as one more interface, on par with the WiFi one, and that this could be done with probably minimal amount of additional code:
==> let users find new usages, new configurations, etc. with these settings, that could greatly help with the upcoming mobile units (and would give potential for more unification of usage between the indoors/outdoors/mobile units.)
(and yes, the same could apply to PoE if it ever was considered as an addition to the hardware
Thanks for your advice, @gabu! Your input is very valuable.
Could you please elaborate more and give some examples of this:
Thank you in advance!
I would see myself for instance having the Airgradient One attached to a self-powered device that would just run prometheus or something similar for data protection, that would share its power with the AgOne, and move accross my building, from floor to floor, apartment to apartment for -say- 10minutes each, to do measures at a given time, and be able to compare if some setting, some activity in one place, has an impact on the other placesâŚ
Or on the range of a huge conference center, where there isnt even wifi coverage everywhere, going from place to place and map measurements along with GPS or accelerometer tracks for instanceâŚ
Or in a old house, which has diffeernt floors, not all of them covered by Wifi, but that may have very different measures of humidity, VOCs, etc.
=> all to do local/offline recordings of measurements from the AgOne, without needing to reset the device and associate it to various wifi networks along the way (especially if in some such places there isnât a wifi network)
=> basically to be able to measure where there is no wifi network (i know it may sound strange to some people, but such places exist! ;))) )
Thatâs an interesting idea anyway!
Some features that you mentioned (GPS and accelerometer) are included in the new AirGradient Go. It uses BLE to communicate with a receiver device (e.g., a smartphone). Do you think BLE (which doesnât require a Wi-Fi connection) is acceptable, or do you think the wired connection (like USB) is still preferable in your use case?
Hey thanks for your interest and the follow-up!
So my personal case doesnât represent anyone but me, but:
1/ i just bought an Airgradient One and i for sure wonât have the budget for your extraordinary mobile device when it gets shipped.
2/ I do not trust bluetooth/BLE more than Wifi. I just dislike it, based on an experience where âweird things happenâ with BT, especially from the gnu/linux stack. things sometimes get de-associated, become slow/janky, are hard to diagnose, but also would require a push of a button (while sometimes you connect to a system remotely and cannot do thatâŚ), etc.
=> in general they have more âmoving partsâ than a goodâol cable, thatâs my philosophy, especially when i design systems to be sturdy, durable and to work unattended for a while.
3/ itâs more opportunistic thinking about your architecture: your device have several âinterfacesâ (wifi / USB for the AgOne, BT / USB for the upcoming portable one, etc.), and you already have embedded code that translates sensorsâ data in many useful outputs/format/endpoints
=> so in order to maximize potential usages, all interfaces could be serving all possible types of formats/endpoints.
I think beyond my preference itâs about enabling as many usages as possible (âbecause we canâ), even the ones you have yet no idea about, and trust the user to find what to do with these many possibilities!
Hi @gabu, thanks a lot again for your interesting view!
Yes, I can relate to what you experience about a Bluetooth mouse, as I have an old Ubuntu laptop, and I have to turn off and on my Logitech mouse every time it boots (the laptop wonât connect to the mouse automatically (there could be a way to solve this, but Iâve not tried maybe)).
Anyway, regarding the feature for the AirGradient ONE, Iâll definitely discuss this with the team. While I cannot make a solid promise on your feature request, as we need to make sure that there is a reasonable number of users who need it, and how practical we can implement and maintain the feature (I know you understand this). Iâd like to say (personally again) that I always love the concept of utilizing, or sometimes, just an experiment, to prove that we can do something with our electronics, just like you mentioned that the reason we should try something is âwhy not?â.
@Tai_AirGradient is the USB log available in older devices? (I have DIY-Pro-Kit-Pre-Soldered-version-3-7 stock at the moment but Im assuming that its firmware can be updated?)
Hi @Ap31 , I hope you are doing well.
You should be able to access the serial log by connecting your PC to the Wemos D1 Miniâs USB-C port.
You can use the firmware web flash tool here (to flash stock firmware or see the serial log):
Please note that I donât currently have the v3.7 hardware, so I cannot verify it myself. Please feel free to let me know if you see any issues. I may be able to find a spare at the office and try it.
