The current airgradient lib doesnāt check checksum from the S8 sensor. This is what is causing bad readings (most of the time).
I donāt have any more issue with reading CO2 value. Moreover, my fork also put to sleep and wakup the PMS sensor at regular interval to increase its longetivity.
All you need to do to use my code, is install VS Code and Platform.IO and update the src/Configuration/User.cpp file with your own Wifi, etc ā¦
I also posted the updated Dashboard that you can import in Graphana
Update graph for graphana with a Temperature and Humidity double graph:
"annotations": {
"list": [
"builtIn": 1,
"datasource": "-- Grafana --",
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"target": {
"limit": 100,
"matchAny": false,
"tags": [],
"type": "dashboard"
"type": "dashboard"
"editable": true,
"fiscalYearStartMonth": 0,
"graphTooltip": 0,
"id": 3,
"iteration": 1645205891893,
"links": [],
"liveNow": false,
"panels": [
"datasource": {
"type": "prometheus",
"uid": "P1809F7CD0C75ACF3"
"fieldConfig": {
"defaults": {
"color": {
"mode": "thresholds"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "#EAB839",
"value": 1000
"color": "red",
"value": 2000
"unit": "ppm"
"overrides": []
"gridPos": {
"h": 6,
"w": 6,
"x": 0,
"y": 0
"id": 5,
"options": {
"orientation": "auto",
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"showThresholdLabels": false,
"showThresholdMarkers": true,
"text": {}
"pluginVersion": "8.4.0",
"targets": [
"datasource": {
"exemplar": true,
"expr": "rco2{id=\"$DeviceId\"}",
"interval": "",
"legendFormat": "",
"queryType": "randomWalk",
"refId": "A"
"title": "CO2 (Latest)",
"type": "gauge"
"datasource": {
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "#EAB839",
"value": 10
"color": "red",
"value": 20
"unit": "conμgm3"
"overrides": []
"gridPos": {
"h": 6,
"w": 6,
"x": 6,
"y": 0
"id": 6,
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {}
"targets": [
"datasource": {
"exemplar": true,
"expr": "particle_count{id=\"$DeviceId\", type=\"PM2.5\"}",
"interval": "",
"legendFormat": "",
"refId": "A"
"title": "PM2.5 (Latest)",
"type": "gauge"
"datasource": {
"fieldConfig": {
"defaults": {
"color": {
"links": [
"targetBlank": true,
"title": "AQI Explanation",
"url": "https://www.airnow.gov/aqi/aqi-basics/"
"mappings": [],
"max": 500,
"min": 0,
"noValue": "Calculating ... (Takes 24h of data)",
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "#EAB839",
"value": 51
"color": "orange",
"value": 101
"color": "red",
"value": 151
"color": "semi-dark-red",
"value": 201
"color": "dark-red",
"value": 301
"unit": "AQI"
"overrides": []
"gridPos": {
"h": 7,
"w": 5,
"x": 12,
"y": 0
"id": 12,
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"showThresholdLabels": true,
"targets": [
"datasource": {
"exemplar": true,
"expr": "air_quality_index{id=\"$DeviceId\", type=\"PM2.5\"}",
"interval": "",
"legendFormat": "",
"refId": "A"
"title": "AQI (PM2.5)",
"type": "gauge"
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": {
"description": "",
"fieldConfig": {
"defaults": {
"unit": "ppm"
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 7,
"w": 12,
"x": 0,
"y": 6
"hiddenSeries": false,
"id": 2,
"legend": {
"alignAsTable": false,
"avg": false,
"current": false,
"max": false,
"min": false,
"rightSide": false,
"show": false,
"total": false,
"values": false
"lines": true,
"linewidth": 1,
"nullPointMode": "null",
"options": {
"alertThreshold": true
"percentage": false,
"pointradius": 2,
"points": false,
"renderer": "flot",
"seriesOverrides": [],
"spaceLength": 10,
"stack": false,
"steppedLine": false,
"targets": [
"datasource": {
"exemplar": true,
"interval": "",
"legendFormat": "CO2",
"refId": "A"
"thresholds": [
"$$hashKey": "object:279",
"colorMode": "warning",
"fill": true,
"line": false,
"op": "gt",
"value": 1000,
"yaxis": "left"
"$$hashKey": "object:285",
"colorMode": "critical",
"fill": true,
"line": false,
"op": "gt",
"value": 2000,
"yaxis": "left"
"timeRegions": [],
"title": "CO2 Over Time",
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"type": "graph",
"xaxis": {
"mode": "time",
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:48",
"format": "ppm",
"label": "",
"logBase": 1,
"show": true
"$$hashKey": "object:49",
"format": "short",
"logBase": 1,
"show": true
"yaxis": {
"align": false
"datasource": {
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "#6ED0E0",
"value": 0
"color": "green",
"value": 18
"color": "#EAB839",
"value": 25
"color": "red",
"value": 30
"unit": "celsius"
"overrides": []
"gridPos": {
"h": 5,
"w": 5,
"x": 12,
"y": 7
"id": 7,
"options": {
"colorMode": "value",
"graphMode": "area",
"justifyMode": "auto",
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {},
"textMode": "auto"
"targets": [
"datasource": {
"exemplar": true,
"expr": "atmp{id=\"$DeviceId\"}",
"hide": false,
"interval": "",
"legendFormat": "",
"refId": "A"
"title": "Temperature",
"type": "stat"
"datasource": {
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"mappings": [],
"max": 100,
"min": 0,
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "#6ED0E0",
"value": 0
"color": "green",
"value": 28
"color": "#EAB839",
"value": 40
"color": "red",
"value": 50
"unit": "percent"
"overrides": []
"gridPos": {
"h": 5,
"w": 5,
"x": 12,
"y": 12
"id": 8,
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {},
"textMode": "auto"
"targets": [
"datasource": {
"exemplar": true,
"expr": "rhum{id=\"$DeviceId\"}",
"interval": "",
"legendFormat": "",
"refId": "A"
"title": "Relative Humidity",
"type": "stat"
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": {
"description": "",
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 6,
"w": 12,
"x": 0,
"y": 13
"id": 3,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"rightSide": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 1,
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"datasource": {
"exemplar": true,
"expr": "particle_count{id=\"$DeviceId\"}",
"interval": "",
"legendFormat": "{{type}}",
"refId": "A"
"thresholds": [
"$$hashKey": "object:188",
"fill": true,
"line": false,
"op": "gt",
"value": 10,
"yaxis": "left"
"$$hashKey": "object:194",
"fill": true,
"line": false,
"op": "gt",
"value": 50,
"yaxis": "left"
"timeRegions": [],
"title": "Particle over Time",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"mode": "time",
"show": true,
"values": []
"yaxes": [
"format": "conμgm3",
"label": "",
"logBase": 1,
"show": true
"format": "short",
"logBase": 1,
"show": true
"yaxis": {
"align": false
"datasource": {
"fieldConfig": {
"defaults": {
"color": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"unit": "dtdhms"
"overrides": []
"gridPos": {
"h": 6,
"w": 5,
"x": 12,
"y": 17
"id": 10,
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"textMode": "auto"
"targets": [
"datasource": {
"exemplar": false,
"expr": "time() - sensors_boot_time{id=\"$DeviceId\"}",
"instant": true,
"interval": "",
"legendFormat": "",
"refId": "A"
"title": "UpTime",
"type": "stat"
"datasource": {
"fieldConfig": {
"defaults": {
"color": {
"mode": "palette-classic"
"custom": {
"axisLabel": "",
"axisPlacement": "auto",
"barAlignment": 0,
"drawStyle": "line",
"fillOpacity": 0,
"gradientMode": "none",
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"lineInterpolation": "linear",
"lineWidth": 1,
"pointSize": 5,
"scaleDistribution": {
"type": "linear"
"showPoints": "auto",
"spanNulls": false,
"stacking": {
"group": "A",
"mode": "none"
"thresholdsStyle": {
"mode": "off"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 60
"unit": "humidity"
"overrides": [
"matcher": {
"id": "byName",
"options": "Temp"
"properties": [
"id": "custom.axisPlacement",
"value": "right"
"id": "unit",
"value": "celsius"
"gridPos": {
"h": 8,
"w": 12,
"x": 0,
"y": 19
"id": 16,
"options": {
"legend": {
"calcs": [],
"displayMode": "list",
"placement": "bottom"
"tooltip": {
"mode": "multi",
"sort": "none"
"targets": [
"datasource": {
"exemplar": true,
"interval": "",
"legendFormat": "Humidity",
"refId": "A"
"datasource": {
"exemplar": true,
"format": "time_series",
"hide": false,
"interval": "",
"legendFormat": "Temp",
"refId": "B"
"title": "Humidity & Temperature",
"type": "timeseries"
"datasource": {
"fieldConfig": {
"defaults": {
"color": {
"custom": {
"axisLabel": "",
"barAlignment": 0,
"fillOpacity": 0,
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"lineWidth": 1,
"pointSize": 5,
"type": "linear"
"spanNulls": false,
"stacking": {
"group": "A",
"mode": "none"
"mode": "off"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"gridPos": {
"h": 5,
"w": 12,
"x": 0,
"y": 27
"id": 14,
"options": {
"legend": {
"calcs": [],
"tooltip": {
"mode": "single",
"sort": "none"
"targets": [
"datasource": {
"exemplar": true,
"interval": "",
"legendFormat": "AQI",
"refId": "A"
"title": "AQI (PM2.5) over time",
"refresh": "1m",
"schemaVersion": 35,
"style": "dark",
"tags": [],
"templating": {
"list": [
"current": {
"selected": false,
"text": "livingroom",
"value": "livingroom"
"datasource": {
"definition": "label_values(rco2, id)",
"hide": 0,
"includeAll": false,
"label": "Device",
"multi": false,
"name": "DeviceId",
"options": [],
"query": {
"query": "label_values(rco2, id)",
"refId": "StandardVariableQuery"
"refresh": 1,
"regex": "",
"skipUrlSync": false,
"sort": 1,
"type": "query"
"time": {
"from": "now-12h",
"to": "now"
"timepicker": {},
"timezone": "",
"title": "AirGradient Uptime",
"uid": "Tvl1xTmRz",
"version": 14,
"weekStart": ""
@ttielemans
