Outdoor Monitor ESPHome Configuration
What’s the best way to do that after the fact? I’m happy to contribute data (especially since there is so little on your map here in my area of the US).
And as a webdev nitpick, that should probably be a 401 error to indicate that the device is not authorized to use the service. A 400 suggests something like malformed JSON.
I’m getting ready to rework my config for DIY and Pro so I can have the device name as part of the sensor like you are doing. In the http_request.post section, I was able to do it with just a json block that was pretty straight forward. Your body with a lambda looks more involved. Is there functionality you are adding or a particular advantage to that method?
Here is what I’m using:
airgradient_esphome/airgradient.yml at main · MallocArray/airgradient_esphome (github.com)
minor note: I haven’t looked into the documentation, but I personally ran into watchdog related errors when using the recommended 5min interval:
interval:
  - interval: 5min
    then:
      - output.turn_on: watchdog
      - delay: 20ms
      - output.turn_off: watchdog
[20:36:13]E (187079) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
[20:36:13]E (187079) task_wdt:  - loopTask (CPU 0)
[20:36:13]E (187079) task_wdt: Tasks currently running:
[20:36:13]E (187079) task_wdt: CPU 0: IDLE
[20:36:13]E (187079) task_wdt: Aborting.
and changing to 3 min (arbitrary value decision)
interval:
  - interval: 3min
    then:
      - delay: 20ms
has so far resolved my issue.
again, not sure why this is the case, but sharing in case anyone else encounters this.
Thanks for putting this together!
One question (for now) – why 18hrs?
substitutions:
  devicename: "airgradient-open-air"
  upper_devicename: "AirGradient Open Air"
  # Initial number of hours to delay AQI results
  initial_aqi_delay: "18"
(sorry if this is an obvious answer, I just haven’t run into this)
It was in the original. My best guess is it was an arbitrary decision to get enough data collected and be close enough to the 24h recommended window for AQI calculations. Personally, I set mine down to 2h and just be aware that the first day is “settling in” … It might be acceptable to drop this delay down to 1h and call it good, and just make sure users are aware that it won’t be “true AQI” for a day. From what I’ve seen in other forum posts, this is what PurpleAir does with some of their units (I think they use 4h).
I do plan to adjust this further and replace the Calculating status string with something like Delay #h (once I come up with a better word for that).
I had just copied the original, but decided to test out yours tonight (still new to esphome, learning as I go along). The main difference seems to be the inclusion of nested channels data, since the outdoor sensor has 2 plus the “combined” sensor data.
I transposed the lambda code into JSON yaml as such:
          json:
            wifi: id(airgradient_wifi_signal).state
            pm01: !lambda return to_string(id(pm_1_0).state);
            pm02: !lambda return to_string(id(pm_2_5).state);
            pm10: !lambda return to_string(id(pm_10_0).state);
            pm003_count: !lambda return to_string(id(pm_0_3um).state);
            atmp: !lambda return to_string(id(temp).state);
            rhum: !lambda return to_string(id(humidity).state);
            boot: "1"
            channels:
              "1":
                pm01: !lambda return to_string(id(pm1_1_0).state);
                pm02: !lambda return to_string(id(pm1_2_5).state);
                pm10: !lambda return to_string(id(pm1_10_0).state);
                pm003_count: !lambda return to_string(id(pm1_0_3um).state);
                atmp: !lambda return to_string(id(pm1_temperature).state);
                rhum: !lambda return to_string(id(pm1_humidity).state);
              "2":
                pm01: !lambda return to_string(id(pm2_1_0).state);
                pm02: !lambda return to_string(id(pm2_2_5).state);
                pm10: !lambda return to_string(id(pm2_10_0).state);
                pm003_count: !lambda return to_string(id(pm2_0_3um).state);
                atmp: !lambda return to_string(id(pm2_temperature).state);
                rhum: !lambda return to_string(id(pm2_humidity).state);
However, that results in a compile error: Must be string, got <class 'esphome.helpers.OrderedDict'>. did you forget putting quotes around the value?. … presumably around the object with 1 and 2 keys. I noticed that the original URL was sending the whole MAC address rather than the last 6 characters like yours did, so I’ve fixed that in my debug code. If that still doesn’t work, I’ll check to see if channels is actually intended to be an array rather than object.
No harm in lowering the interval. The watchdog needs to be activated within a certain time depending on the resistor connected. I calculated its about 8min but yours could be shorter. As long as you feed it in time it will not reset.
Update on the JSON stuff: I tracked down the official AirGradient Outdoor code and confirmed the JSON format is indeed sending an object with keys of 1 and 2. And as far as I can tell, that Must be a string error is a “feature” of espHome itself: it just doesn’t supported nested properties via the json option.
The code also showed that it should be sending the full MAC address in the URL, so I’ve restored that in my copy. I’ll find some time this weekend to fork the repo and get my changes onto github rather than lazily relying on my clipboard history as version control. I also have some updates for the DIY Pro sensor firmware that I want to get in place.
I’m not so sure on the full MAC. It looks like the ESP.getChipId() function returns the last 3 bytes in HEX and not the full MAC
arduino-esp32/GetChipID.ino at master · espressif/arduino-esp32 · GitHub
I haven’t played with ESPHome with a JSON that has multiple keys, but there may be some YAML formatting to have it format more as expected. I haven’t tried any of this, but in YAML, it would be something like
            channels:
              - 1:
              - 2:
Or maybe not naming the keys, but just making it a list:
            channels:
              -  pm01: !lambda return to_string(id(pm1_1_0).state);
              -  pm01: !lambda return to_string(id(pm2_1_0).state);
Oh, that was totally an assumption on my part that it would return the whole value. Thanks for catching that.
Yeah, it’s not the YAML itself that’s problematic, but the validator for the json property is set as “strict string”: esphome/config_validation.py at 8bb4c65272b41ccc6fa25a9e39096617c8c041c5 · esphome/esphome · GitHub
I spent way too much time poking at this, but it’s been a good leaning project for ESPHome. My version of the file is now on github (link at the end of this post). I haven’t yet submitted an upstream pull request because I’m waiting a couple days for AQI and NowCast to show up and make sure they’re consistent and the system is stable.
Major rewrite: AQI + NowCast
I now have a better understanding if AQI, and see why it’s something
that needs to be a “once/day” calculation. To that end, I’ve added
NowCast calculations, which require keeping track of the hourly
averages. This actually paves the way for storing the values in
flash so they can be restored across reboots and speed up
re-calculation (though we’ll need to track the hours that each avg
comes from so we can age out too-old values).
  • Rewrite AQI calculation based on official standards.
    • No more separate 2.5 and 10 variants. AQI is AQI, and there is no
      reason to provide the separate pseudo-AQI calculations. Plus, it
      was a lot of duplcated code for little benefit.
    • Document why we use 18 hours not 24: the official spec allows for
      calculations once we hit 75% data availability.
    • Note: This calculation still differs from the official AQI , which
      is apparently calculated midnight-to-midnight rather than a 24h
      rolling average.
  • Add NowCast. This is a 12h version of AQI weighted to the most recent
    hour, and is a better fit for what a lot of people want from AQI: a
    measurement of air quality during short-term quality issues like
    wildfire smoke.
  • Add sensors to report on the number of minutes remaining before AQI
    and NowCast are available.
  • Update some sensors to report 1 accuracy decimal instead of 0.
  • Changes around a few icons.
  • Fixes some math and timing values.
  • More inline comments/documentation.
Also includes previous work:
  • Make initial_aqi_delay configurable. I’ve arbitrarily chosen 4h here, and
    have some ideas how to make it better in the future because I like seeing
    numbers and can trust myself to know it’s not particularly accurate before
    24h.
  • Turned on the captive portal (fallback hotspot is kind of useless without
    it)
  • Included a section for Home Assistant API and encryption key (stored as a
    secret)
  • Separated AQI into pm2.5, pm10.0, and a generic AQI that matches whichever
    value is highest. Only the “best of” AQI values are sent to Home Assistant
    by default.
  • Set a bunch of the values to disabled_by_default: true so only the
    combined/average values show up by default in Home Assistant.
  • Extended the AQI calculations to the maximum of 500 if particle readings
    are REALLY bad (hello west coast wildfiles … I know some people who were
    caught in areas “above 500”).
  • Tried to clean up the AQI calculations (both numeric and text) to be
    easier to read/maintain.
  • Switched around a few of the icons:
    • mdi:blur seems to be a popular one for particle count
    • Home Assistant seems to use the plain mdi:thermometer icon for
      temperatures
    • Use mdi:weather-windy-variant for AQI, which matches Home Assistant’s
      use of it for the air_quality integration.
Wow, you really outdid yourself. When I did the AQI calculation a year ago I just settled for that 18h and didnt want to bother with calculating provisional numbers. And just build up data after that initial start. I still had issues with spikes in the input sensor which causes the AQI to bump hours later which should be compensated for I think.
I will try your code both on inside and outside unit soon.
Make sure to pull the latest. I found some issues after my original changes. Things appear to be stable and calculating properly now.
I also have a bit of cleanup for the DIY Pro version (spent way too much time finding better-looking fonts) but will find an appropriate thread to post about those updates.
And in case anyone is curious, here’s the card I’m using in Home Assistant. It uses stack-in-card, card-mod, and mini-graph-card from HACS.
type: custom:stack-in-card
mode: vertical
keep:
  background: true
  border_radius: false
  margin: false
cards:
  - type: markdown
    content: >
      {%- set category =
      states('sensor.airgradient_open_air_airgradient_open_air_nowcast_category')
      {% if category == "unknown" %} # NowCast: Calculating
      {% set mins =
      states('sensor.airgradient_open_air_nowcast_minutes_remaining')
      | int %} Available in {% if mins > 60 %}{{ mins // 60 }} hours {% endif
      %}{{ mins%60 }} minutes
      {% else %}
      # NowCast: {{ category }}
      {% endif %}
    card_mod:
      style: |
        ha-card {
          {% set aqi = states('sensor.airgradient_open_air_airgradient_open_air_nowcast') -%}
          {%- set aqi = aqi | float if is_number(aqi) else -1 -%}
          {%- if aqi < 0 -%}
            background-color: #a0a0a0; color: #393939;
          {%- elif aqi < 50 -%}
            background-color: #00e400; color: #004000;
          {%- elif aqi < 100 -%}
            background-color: #ffff00; color: #404000;
          {%- elif aqi < 150 -%}
            background-color: #ff0000; color: #400000;
          {%- elif aqi < 200 -%}
              background-color: #8f3f97; color: #300030;
          {%- else -%}
            background-color: #7e0023; color: #200000;
          {% endif %}
          text-align: center;
        h1 {
          line-height: 1px;
          margin: 0 !important;
          padding: 0 !important;
          border: 1px solid red !impotant;
  - type: conditional
    conditions:
      - entity: sensor.airgradient_open_air_airgradient_open_air_nowcast
        state_not: unknown
    card:
      type: gauge
      needle: true
      min: 0
      max: 500
      segments:
          color: '#00e400'
          color: '#ffff00'
          color: '#ff7e00'
          color: '#ff0000'
          color: '#8f3f97'
          color: '#7e0023'
  - type: custom:mini-graph-card
    entities:
    color_thresholds:
      - value: 0
        color: '#00e400'
      - value: 50
        color: '#ffff00'
      - value: 100
        color: '#ff0000'
      - value: 200
        color: '#8f3f97'
      - value: 300
        color: '#7e0023'
    show:
      labels: false
      fill: fade
      state: true
      icon: false
    min_bound_range: 20
    line_width: 4
    hours_to_show: 24
    points_per_hour: 1
    card_mod:
      style: |
        div.states {
          display: none !important;
          position: absolute;
          bottom: 0;
          left: 0;
        ha-card:hover div.states {
          display:block !important;
  - type: markdown
    content: |
      {%- set category =
      states('sensor.airgradient_open_air_airgradient_open_air_aqi_category')
      -%} {% if category == "unknown" %} # AQI: Calculating
      {% set mins = states('sensor.airgradient_open_air_aqi_minutes_remaining')
      {% else %} # AQI: {{ category }} {% endif %}
    card_mod:
      style: |
        ha-card {
          {% set aqi = states('sensor.airgradient_open_air_airgradient_open_air_aqi') -%}
          {%- if aqi < 0 -%}
          {%- else -%}
          {% endif %}
          text-align: center;
        h1 {
          line-height: 1px;
  - type: conditional
    conditions:
      - entity: sensor.airgradient_open_air_airgradient_open_air_aqi
        state_not: unknown
    card:
      type: gauge
      needle: true
      min: 0
      max: 500
      segments:
          color: '#00e400'
          color: '#ffff00'
          color: '#ff7e00'
          color: '#ff0000'
          color: '#8f3f97'
          color: '#7e0023'
    entities:
    color_thresholds:
      - value: 0
        color: '#00e400'
      - value: 50
        color: '#ffff00'
      - value: 100
        color: '#ff0000'
      - value: 200
        color: '#8f3f97'
      - value: 300
        color: '#7e0023'
    show:
      labels: false
      fill: fade
      state: true
      icon: false
    min_bound_range: 20
    line_width: 4
    hours_to_show: 24
    points_per_hour: 1
    card_mod:
      style: |
        div.states {
          position: absolute;
          bottom: 0;
          left: 0;
  - type: horizontal-stack
    cards:
        entities:
          - entity: >-
              sensor.airgradient_open_air_airgradient_open_air_particulate_matter_1_0um_concentration
            state_adaptive_color: true
            color: wheat
        line_width: 2
        hours_to_show: 24
        min_bound_range: 10
        show:
          labels: false
          fill: fade
          icon: false
          name_adaptive_color: true
        entities:
          - entity: >-
              sensor.airgradient_open_air_airgradient_open_air_particulate_matter_2_5um_concentration
            color: tan
        line_width: 2
        hours_to_show: 24
        min_bound_range: 10
        show:
          labels: false
          fill: fade
          icon: false
        entities:
          - entity: >-
              sensor.airgradient_open_air_airgradient_open_air_particulate_matter_10_0um_concentration
            color: burlywood
        line_width: 2
        hours_to_show: 24
        min_bound_range: 10
        show:
          labels: false
          fill: fade
          icon: false
columns: 1
For those following along, I submitted a PR for my changes to both the Outdoor/Open Air and DIY Pro models: Quality of life and other (somewhat major) updates for AirGradient Outdoor and DIY Pro by ex-nerd · Pull Request #17 · ajfriesen/ESPHome-AirGradient · GitHub
Is there a way to save/restore 24 hours of data so that on a reboot it doesn’t have the delay for AQI and Now Cast?
It’s possible to store numbers on the flash on the device, but the info I found basically says it has about 10k writes before it starts to degrade. With hourly updates, that’s about a year and a half before the device stops working properly.
Others are doing the calculation in Home Assistant itself, but I haven’t had time to look into how to actually query past/logged states and build that into a value that can be added to a dashboard.
Great to see such an active discussion on the new outdoor monitor and ESPHome integrations.
The flash chip on the C3 is indeed limited with write cycles and I would also recommend to offload the calculation to the server and only transmitting raw data. This gives more flexibility to show also the last current measured data to show trends etc.
I received my outdoor kit last week and have been testing this esphome configuration since then and other than the 18h/12h delays it has been working well.
My problem has been that a few very small power interruptions return the 18h/12h delays on the AQI making it hard to rely on the value.
I also experienced reboots (crashes?) when the device can’t upload to airgradient (internet outage or firewall block) which again end up restarting the counter.
I finally commented out the upload to airgradient and added the calculations to home-assistant. The AQI was pretty straightforward using a 24h statistic sensor and template sensors. But the NowCast is complex to do in Home-Assistant using the official calculations. After testing a few scenarios it seems that using a 3h statistics sensor with the AQI calculations return values that are very close to the NowCast values returned by Esphome.
*The AQI is off at the beginning of the graph because of a 18h/12h reset
Regarding the query for statistics from Home-Assistant, this can be done using the websocket API. I don’t think it is documented but the relevant code in Home-Assistant is here
If any one is interested here are my configurations for Home-Assistant sensors
## AQI 3h
sensor:
  - platform: statistics
    name: PM2.5 Mean 3h
    unique_id: pm2_5_mean_3h
    entity_id: sensor.airgradient_airgradient_open_air_particulate_matter_2_5um_concentration
    state_characteristic: mean
    max_age:
      hours: 3
    name: PM10 Mean 3h
    unique_id: pm10_mean_3h
    entity_id: sensor.airgradient_airgradient_open_air_particulate_matter_10_0um_concentration
    max_age:
      hours: 3
    name: PM2.5 Mean 24h
    unique_id: pm2_5_mean_24h
    max_age:
      hours: 24
    name: PM10 Mean 24h
    unique_id: pm10_mean_24h
    max_age:
      hours: 24
template:
  - sensor:
      - name: "AQI EPA PM2.5 3h"
        unique_id: aqi_epa_pm25_3h
        device_class: aqi
        state: >
          {% set pm25 = states('sensor.pm2_5_mean_3h')|float %}
          {% if pm25 < 12.0 %}
            {{ ((50.0 - 0.0) / (12.0 - 0.0) * (pm25 - 0.0) + 0.0)|round }}
          {% elif pm25 < 35.4 %}
            {{ ((100.0 - 51.0) / (35.4 - 12.1) * (pm25 - 12.1) + 51.0)|round }}
          {% elif pm25 < 55.4 %}
            {{ ((150.0 - 101.0) / (55.4 - 35.5) * (pm25 - 35.5) + 101.0)|round }}
          {% elif pm25 < 150.4 %}
            {{ ((200.0 - 151.0) / (150.4 - 55.5) * (pm25 - 55.5) + 151.0)|round }}
          {% elif pm25 < 250.4 %}
            {{ ((300.0 - 201.0) / (250.4 - 150.5) * (pm25 - 150.5) + 201.0)|round }}
          {% elif pm25 < 350.4 %}
            {{ ((400.0 - 301.0) / (350.4 - 250.5) * (pm25 - 250.5) + 301.0)|round }}
          {% elif pm25 < 500.4 %}
            {{ ((500.0 - 401.0) / (500.4 - 350.5) * (pm25 - 350.5) + 401.0)|round }}
          {% else %}
            500
          {% endif %}
      - name: "AQI EPA PM10 3h"
        unique_id: aqi_epa_pm10_3h
        device_class: aqi
        state: >
          {% set pm10 = states('sensor.pm10_mean_3h')|float %}
          {% if pm10 < 54.0 %}
            {{ ((50.0 - 0.0) / (54.0 - 0.0) * (pm10 - 0.0) + 0.0)|round }}
          {% elif pm10 < 154.0 %}
            {{ ((100.0 - 51.0) / (154.0 - 55.0) * (pm10 - 55.0) + 51.0)|round }}
          {% elif pm10 < 254.0 %}
            {{ ((150.0 - 101.0) / (254.0 - 155.0) * (pm10 - 155.0) + 101.0)|round }}
          {% elif pm10 < 354.0 %}
            {{ ((200.0 - 151.0) / (354.0 - 255.0) * (pm10 - 255.0) + 151.0)|round }}
          {% elif pm10 < 424.0 %}
            {{ ((300.0 - 201.0) / (424.0 - 355.0) * (pm10 - 355.0) + 201.0)|round }}
          {% elif pm10 < 504.0 %}
            {{ ((400.0 - 301.0) / (504.0 - 425.0) * (pm10 - 425.0) + 301.0)|round }}
          {% elif pm10 < 604.0 %}
            {{ ((500.0 - 401.0) / (604.0 - 505.0) * (pm10 - 505.0) + 401.0)|round }}
          {% else %}
            500
          {% endif %}
      - name: "AQI EPA 3h"
        unique_id: aqi_epa_3h
        device_class: aqi
        state: >-
          {{ [states('sensor.aqi_epa_pm10_3h')|int, states('sensor.aqi_epa_pm2_5_3h')|int]|max }}
      - name: "AQI EPA Category 3h"
        unique_id: aqi_epa_category_3h
        state: >-
          {% set aqi = states('sensor.aqi_epa_3h')|int %}
          {% if aqi <= 50.0 %}
            "Good"
          {% elif aqi <= 100.0 %}
            "Moderate"
          {% elif aqi <= 150.0 %}
            "Unhealthy for Sensitive Groups"
          {% elif aqi <= 200.0 %}
            "Unhealthy"
          {% elif aqi <= 300.0 %}
            "Very Unhealthy"
          {% elif aqi <= 500.0 %}
            "Hazardous"
          {% else %}
            "Extreme Hazardous"
          {% endif %}
      ## AQI EPA 24h
      - name: AQI EPA PM2.5
        device_class: aqi
        state: >
          {% set pm25 = states('sensor.pm2_5_mean_24h')|float %}
          {% else %}
            500
          {% endif %}
      - name: "AQI EPA PM10"
        device_class: aqi
        state: >
          {% set pm10 = states('sensor.pm10_mean_24h')|float %}
          {% else %}
            500
          {% endif %}
      - name: "AQI EPA"
        unique_id: aqi_epa
        device_class: aqi
        state: >-
          {{ [states('sensor.aqi_epa_pm10')|int, states('sensor.aqi_epa_pm2_5')|int]|max }}
      - name: "AQI EPA Category "
        state: >-
          {% set aqi = states('sensor.aqi_epa')|int %}
            "Good"
            "Moderate"
            "Unhealthy"
            "Very Unhealthy"
            "Hazardous"
          {% else %}
            "Extreme Hazardous"
          {% endif %}
Great work, thanks for the info. I’ve been looking into the SQL plugin to get at the raw data to do the AQI and NowCast stuff but this is certainly easier. I’ll probably still do a deeper dive into this because I want to learn the APIs and get an “actual proper calculation” written (just for the sake of doing it … I think the official midnight-to-midnight AQI isn’t helpful within a home assistant context) but this really helps me get a head start on how to get at some of this info.
