For some reason I don’t yet understand, OpenHAB shows Airgradient humidity as, e.g., 0.42. Even though the channel is declared with min=0 max=100:
Maybe it would already help if OpenHAB would report 42.0 instead of 0.42. To be frank, I am quite confused how OpenHAB processes and presents numeric values. All I know is that for other humidity sensors, like Homematic, I needed to create an extra item that presents humidity in the 0-100 range, an not in the 0-1 range, for other consumers, like Google Assistant/Google Home, to correctly process and display it.
Yes, it would be great to get a statement from Airgradient here, if the returned values will always be integers. CC @Achim_AirGradient
I think the Airgradient firmware already does exactly that, if a value is a float, e.g., because it was calculated as the average of two sensor values, then it is still represented as integer. Which, I guess, is for most values besides temperature sensible.
BTW, looking at my OpenHAB logs, I found:
[DEBUG] [l.handler.AirGradientLocationHandler] - Channel name tvoc is null
It looks like tvoc is not correctly wired up in the local case , as it’s either tvocIndex or tvoc_raw in the JSON.
