DIY unit not reporting into Dashboard
Hello,
Built DIY unit solved reboot issue. Only issue now is unit not reporting into Dashboard.
What is the device ID format? Please can someone give me an example as its not clear what it is.
kid regards
Peter
I managed to get it reporting by using the part of the WiFi SSID after the dash as device-ID/sensor-ID.
You see this very short after restarting the unit.
Hi,
Thanks for the message.
When the device initially boots it displays AG-54809e before it connect to my WiFi and warms up the sensors.
Which part is the ID?
kind regards
Peter
OK solved and thankyou rhermsen all working now.
The lower case e was the issue.
Could you tell me how you solved this, as I have the same issue: "When the device initially boots it displays AG-XXXxx before it connect to my WiFi and warms up the sensors.
Which part is the ID?"
I found the answer here: Finding the DIY board's serial number (AirGradient dashboard integration) - #6 by David
