AirGradient Open Air Max (O-M-1PPST) - No Home Assistant Support - Looking for Workarounds
I’m happy to say @MallocArray that the wifi connectivity does indeed work after flashing to v0.5.1 :slight_smile:
Is the HomeAssistant integration still somewhere on the horizon, or has this been dropped entirely? I’m only asking if I should look as a precaution for the summer (in the northern hemisphere) into alternative approaches (probably some duct-taped MQTT).
Additionally I noticed that the Open Air Max doesn’t really auto-update and neither was the firmware doc on the main site updated with the newest firmware release versions, nor does the github README contain any installation instructions.
Therefore - could you advise what IS the recommended firmware update approach? :slight_smile:
I haven’t seen any further mention of Home Assistant for the Max. I think it will need a whole new Integration for the cellular connectivity so HA can pull the data from the online Dashboard site instead of directly from the device.
I don’t know if the current HA integration is expected to find it if using Wifi, I had only tested it for a short while and then went back to Cellular for further testing.
The firmware status is pretty incomplete in my opinion. As you found you can’t specify a firmware version in the Dashboard for the Max, but it will change firmware if you manually flash up to a newer one.
You could use the Support page on the main site and give them your serial number and ask them to set your device to the latest firmware, which I think is 0.7.0. They have set mine to specific versions in the past during testing.
Yes, we’re still working on firmware and even the hardware. When things stabilize on those fronts, I would expect updates on integrations.
Don’t know about that, but I would assume that in the very least adjusting the existing integration to poll the Air Gradient Max over wifi should be relatively straightforward.
I would strongly assume it uses mDNS to discover new devices on the local network.
THIS actually sounds like a bigger issue than the lack of support for HA :wink:
@Altair_AirGradient what is your current recommendation? NOT to upgrade at all? Or would you say that main site / documentation / firmwares (for some reason I cannot repost the link) needs to be updated with the latest binaries?
Not to pressure you @Altair_AirGradient at all, but would you say that it’s realistic you will “come around” to the integration in ~3-4 months? I’m fine with it being (much) more, it’s just that I would need to start looking now into “alternative solutions” as a bridge for this season :wink: The information itself is valuable to me, even if it is “negative”.
Hi @devious-joke - I think we’re starting to move to a more stable state with the firmware now. We are discussing rolling out the latest stable version globally after testing is complete. The latest version addresses a lot of issues (connectivity, battery optimizations) and appear to do well generally.
There will be an update to the firmware update page as well. In a few weeks time, the latest stable release will be automatically made available via the firmware update page with no manual intervention needed.
Thanks @Altair_AirGradient for keeping us all in the loop.
Much appreciated.
Hi @Altair_AirGradient, picking this thread back up.
Model: O-M-1PPST-CE running on firmware 0.9.1 - are there any news regarding Home Assistant (https://www.home-assistant.io/) support?
Back in February you mentioned the firmware was nearing a stable state and that integration updates would follow once things settled on that front. I’m now on 0.9.1, so it looks like there’s been good progress since then - just wanted to check whether HA integration work has started, or if there’s still no concrete timeline. Thanks for keeping us posted either way.
Hi @stachrom, there is no update on this as of now. I will follow this up with our team as soon as our AirGradient Go post-launch phase stabilizes. We’ll let you know when there is an update!
