How did you make the house dusty/smokey? For example, typical house dust is much bigger than 2.5 microns. It would correctly not be detected by the PMS5003 sensors.
The PMS5003 and PMS5003T should give you a strong response when you extinguish a candle ca. 1 meter away. An extinguishing candle normally emits a lot of airborne particles below 2.5 microns. You should also see a clear (probably less intense) signal when spraying deodorant or fragrance next to the sensors.
